08-20-2006, 05:06 PM
Anyone from houston texas?
08-20-2006, 06:45 PM
Re: Anyone from houston texas?
sent you a pm and sent email to H1 for location.  If you buy it I want to take it offroading, just to test it of course
08-20-2006, 08:43 PM
I live very close to houston.........send me the money and I'll run over a buy it for ya...
08-21-2006, 03:24 PM
If it is to far drom the Doc, I can help out. I am on the northwest side of Houston.
Want-08 Viper, 06 M5
08-21-2006, 03:32 PM
So am I, so let me know.
08-21-2006, 03:41 PM
 I am too!
08-21-2006, 05:05 PM
I emailed H1, He said if I was serious buyer. I emailed again to get which area of Houston he's in so someone close can go look.
08-21-2006, 07:23 PM
i hate waiting...  i will have an ulcer!!
08-21-2006, 07:25 PM
The truck belongs to a local doctor. We have done all the service work on his truck. It is in great shape..
Auggie
08-21-2006, 08:14 PM
looks like a cream puff in the photos
08-22-2006, 02:38 AM
So do I-photos lie so bad..
08-22-2006, 02:55 AM
Dont laugh but i dont understand this.Can you explain it?
08-23-2006, 01:11 PM
I talked to the Doc. He assured me the vehicle is in excellent condition. Never flooded. Serviced every 3,000 with documentation. If Auggie says its in good shape, you can bid confidently. Good Luck, You'll be getting a great truck.
08-23-2006, 05:47 PM
"Q: Hi are you sure your H1 hummer is not flood damage, i did check it whit auto check it shows it has storm title or some like that please let me know what is the true thanks Aug-18-06  A: I am not sure what the storm title refers to but the car never had flood damage"
I think it's referring to "Desert Storm"
'03 H2
08-23-2006, 06:41 PM
If you choose to buy it MAKE SURE IT HAS HAD THE ENGINE REPLACED!!! Also get the cooling system pressure tested, have a dealere bring the system up to 15 PSI and let the truck sit for a half hour, it should not drop more then a couple of PSI, again dont touch this truck or any other 96-99 HUMMER without ensuring that these things have been done.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
08-23-2006, 08:05 PM
Ok Why??? I admit to being ignorant about the H1
08-23-2006, 10:38 PM
motor is original one ( 8 cylinder danger =i know and that is  why i am hesitating!!)
08-23-2006, 11:56 PM
The Turbo Diesel H1's produced from 96-99 had a flaw in the casting on the number 8 cylinder, causing the blocks to crack.
-007=
08-24-2006, 12:01 AM
Honestly I would pass it up then. A new engine is not cheap, to have a HUMMER dealer install it will run you between 12-15K depending on the dealer. If you really do have your heart set on it though just get it pressure tested like I said earlier, that will tell you weather or not the engine is bad. If it is still good and you would like to buy the truck there is one thing you can do, add a rear head cooling kit. There is an HML member that has a 97.5 with over 130K on the odo with its original engine, he put the kit on almost immediately purchasing the truck. Thought I will say, a cooling kit will NOT guarantee that you wont have the engine fail, its insurance, nothing more.
-007=
