Old 08-21-2006, 05:00 PM
mowdoc mowdoc is offline
mowdoc is on a distinguished road
Default SIR-GM1 to 06 factory Nav with NO XM
IT WORKS GREAT!! Just be ready to do a long install.
OK - I wanted the Sirius built in to my 06 H2 that had the stock touch screen Nav and did not come with XM or 6 disc CD changer. I was using the Sirius Starmate with replay but the glare from this thing at night was too much and since I was running thru the antenna, I was hearing analog music.
Install of the SIR-GM1 was time consuming to say it nicely. I have changed the dash panels before (thanks Stuart) and have experience with that or I would still be installing this thing.
I have read, and believe them, that some people can reach the plugs on the back of the radio. I could not. So I had to unbolt the console and move it back a couple of inches. Then the center dash panel and the passenger dash panel had to come off as well. The glove box was dropped open to provide the best accessability. Once the dash was out of the way I removed the radio/nav unit. Now the plugs were easy to see/figure out and change. After the supplied "T" harness was plugged into the radio/nav unit it was installed back into the dash. The harness is too short to put the Sirius anywhere except on the pass side of the radio. Double sided tape worked perfect for this. The wiring was easy and everything you need comes in the kit. It is easy to figure out and things plug right in. Next was the 12 volt power supply needed for the new unit. I ran this from the fuse block on driver side of dash.
The antenna was mounted between the sunroof and the front right amber clearance light on top. One screw removes this light. Then I ran the wire thru the light wire grommet and fished it down the right A pillar then under the dash to the tuner. It took a few minutes of fishing with a coat hanger and help from the wife to do this but it come out very clean and was worth the effort.
How does it sound? - SWEEEEET!! CD quality for sure.
The touch screen display still says XM1 and XM2 when selected but down near the title and artist it says Sirius. Title and Artist do not scroll. The channel and catagory are displayed as well as time of day. The screen still shows the big H2 when booting up as it did before. There are a couple of display options that seem worthless to me but others may use them.
All of the steering wheel controls work perfectly. The best part is you can shut down the screen for night driving.
The down side - direct access channel selection can not be made from a keypad. You must use presets or scroll thru all the channels by using the channel select or search bottons.
I bought the SIR-GM1 at Circuit City for $99. They would install it for $105. This may be worth it to many. I prefer to do my own work. At least I know all the screws got put back and if the dash rattles I know who to blame.
Bottom Line - the SIR-GM1 works as advertised. It NEEDS direct channel access IMO. The sound is great. Everything you need comes in the kit except for a short wire for 12 volt power and a piggy-back fuse holder.
Most will need to plan an entire afternoon or pay for the install.
mowdoc
2006 H2 Adventurer loaded named "Wolfey Boy" - Pewter Silver/Wheat - Denali wood dash panels - SIR-GM1 Sirius
Wifey's ride is a 2007 Corvette 3LT F55 A6 named "Lucy"
2001 Jeep TJ with heavy mods is my off-roader - the Hummer stays clean
