Old 08-30-2006, 04:39 AM
br549er br549er is offline
br549er is on a distinguished road
Default Rancho shocks stock height
Thinking about installing Rancho 9000 shocks. Has anyone had any experience with them?
Old 08-30-2006, 04:54 AM
Big Z Big Z is offline
Default Re: Rancho shocks stock height
get um!
Old 08-30-2006, 12:13 PM
md_sailor's Avatar
md_sailor is off the scale
It's been said by others here ( and I agree 100%) that it should have been the first Mod Made. The difference is remarkable. + it's nice to have options with regard to adapting the ride to match the terrain.
Old 08-30-2006, 02:48 PM
I've had them for.... a while or so. Love 'em.
Old 08-30-2006, 02:53 PM
tomp's Avatar
tomp tomp is offline
Phil, I noticed the Rod Hall Shocks sold by Hummer are also High Pressure for the rear shocks. It almost seems this might be a requirement to meet the load carrying capacity for the rear suspension.
Rod Hall Shocks
"These shocks have a patented inertia active valve that adjusts automatically to any conditions. It's remote reservoir allows for extra oil capacity and cooler operation and it's high pressure gas-charged monotube construction eliminates foaming of the oil and dissipates heat more effectively for increased durability."
Old 08-30-2006, 03:14 PM
Rod Hall Shocks
All monotube shocks are high pressure charged. It has nothing to do with the vehicle. It has to do with keeping the oil in suspension and not foaming up.
Some shock manufacturers feel that monotube design removes heat better, but it will also lead to oil foaming if the pressure applied to the oil is not high enough to keep it in suspension.
Old 08-30-2006, 03:24 PM
tomp's Avatar
Monroe/Rancho claim they are the manufacturer for the OEM Hummer shocks and they are 285psi and they consider them 300psi (rounded the number off)
Old 08-30-2006, 03:43 PM
Originally Posted by PhilD
Kind of what I always thought, but have been hearing different things about the actual pressure. One way to usually tell a high pressure (200-300 psi) shock is they usually come strapped to make them easier to install.
Yeah, the pressures vary greatly and are different for each vehicle. Apparently when they designed the coil sprung rear on the H2, they designed it with a very high pressure gas charged shock that offers some "lift."
Apparently, aftermarket shock makers don't know what charge to have either. Just because a shock says it's high pressure charged doesn't mean it is charged correctly for the sprung H2 because all monotube shocks are charged.
There are pros and cons to monotubes vs. multitubes. Multitubes will not be high pressure charged though and will not offer the "lift" like was designed into the rear of the H2. Many of the off-road shocks are multi-tube design.
Old 08-30-2006, 07:47 PM
H2 Bill H2 Bill is offline
Love them. They are great. Drives like a different vehicle.
Old 08-30-2006, 08:07 PM
GREAT SHOCKS!
Now, on my 06 H2 SUV, I put the Ranchos on and noticed no difference in ride height in the rear. This truck seems to sit higher in the rear than any of my previous H2's with air susp. or the springs. This one has springs and sits very level (no sag). The SUT I had was also riding on Rancho 9000's and had springs, that one did sag in the rear before and after the shock change. So I can only assume that there are different runs on the springs and that spring height wil vary?? Regardless of shocks?
Old 08-30-2006, 08:15 PM
Rod Hall Shocks
http://www.elcovaforums.com/forums/s...ad.php?t=19205
