Old 08-30-2006, 06:15 PM
jp's-h3 jp's-h3 is offline
Default ----------NO MORE ROCK CHIPS!----------
------Well, on the rear fenders anyway!------
I've been wanting to try this for sometime now, I got a wild hair on Monday, and did it!
I thought it would be a good alternative to the spray-on materials.
an added bonus to this is that you can remove it if needed.
first you need to go to your local snowboard or skateboard shop.
1- I purchased a 3'x9" piece of grip tape (about $5.50).
2- I made a template out of paper of the front of the rear fender.
Cut out the template and make any necessary adjustments to the pattern.
4- Trace the template onto the backside of the sheet of grip tape and cut out.
5- When applying the grip tape to the fender, only peel a few inches of the backer at a time, this stuff is pretty sticky and if you peel it all at once you could have one heck of a mess on your hands!
So, apply a little bit at a time and line it up as you go. Take your time and it will come out real nice!
6- Once applied, rub out toward the edges using leather gloves(you will take the skin right off your hands) so you don't get any bubbling.
Well that's about it, you shouldn't have any problems w/ the tape conforming to the shape of the fender, just work the tape out toward the edges as you apply it and you'll be as good as gold!
I will take orders for the precut fender protection
(2) Precut fender protectors w/shipping: $30.00
Old 08-30-2006, 07:13 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Default Re: ----------NO MORE ROCK CHIPS!----------
it looks pretty good, but i have a feeling you may regret it when you a) go 4wheeling through mud and b) try to clean said mud from grip tape.
I hope i'm wrong because it does look pretty good and serves a purpose.
Old 08-30-2006, 08:17 PM
I agree, may be a fade and dirt problem, looks good for now
Old 08-30-2006, 08:36 PM
I played in the mud on tuesday morning, washed it afterwards and the mud washed right off!
Old 08-30-2006, 08:38 PM
I've done this on other vehicles w/ no fading problems.
Old 08-30-2006, 08:46 PM
cestwick's Avatar
cestwick cestwick is offline
cestwick is off the scale
Can't collect more mud then Line-x and it cleans up nice..
'06 H3 Shadow Green, Adventure, 6 disk Monsoon, SMA brush guard w/PIAA lights, Rocky Road extreme rocker protection, roof lights(off road), lower grill lights(off road), Helo Maxx8 Black Wheels, 35" Cooper STT, Garmin I-Que M4 to get home.
Old 08-30-2006, 08:50 PM
Looks nice!
Old 08-30-2006, 09:34 PM
fourfourto's Avatar
Another GR8 inexpensive idea.
Im still waiting on that beer
Also I found when applying sticky type material you spray down the area with water with a drop or two of dish soap it can be moved around a bit press out extra water and let it dry it will bond to surface.
I did that with my vertical fender stripes on the 442.
Old 08-31-2006, 10:27 PM
Thanks fourfourto!
Let me know if your ever in the area or in MOAB, and the first pitcher is on me!
Old 08-31-2006, 10:56 PM
ETD's Avatar
ETD ETD is offline
ETD is an unknown quantity at this point
Man, you are one heck of a McGyver. If I'm ever stuck in the jungle, I hope that you or 424 are part of the group. When's the small power motivator coming on line?
Old 09-01-2006, 05:07 AM
I'm working on it!
Old 09-01-2006, 05:37 AM
H3slate's Avatar
H3slate H3slate is offline
Wakizashi
Where do you keep your sword?
Old 09-02-2006, 10:53 PM
Where do you think!
