Old 08-31-2006, 06:29 PM
Default Muffler bearings
After 60K+ miles of squeaky door panels, running over small cars and way to many gallons of gas burned, I have encountered my first problem with my 05. Muffler bearings are bad. Sounds like hell. I was parking in the garage when I heard this sound which was like ball bearings inna tin barrel bouncing around. I thought it was transmission/drive case origined. After putting Kong in park and slowly increasing rev of the engine, I noticed the sound got a little louder,then dissapeared. Came back at idle. Ouch-maybe converter? So i slid under the beast with my Klein knock sensor tool. Placing the screwdriver to my ear, then the metal tip to the engine, I heard no problems...just a nice whirring of GM power. Check transmission-Nope. T-Case? Nope. Damn...guess Ill listen to the exhaust. DAMN! Loud as hell..and louder towards the muffler. A listen to the muffler confirmed my sounds origin..the muffler is rattling-must have broken a spot weld inside.
On the better side, this now allows me to make that Zoomers exhaust system buy I wanted. X-pipe, here I come!
Want-08 Viper, 06 M5
Old 08-31-2006, 06:50 PM
Default Re: Muffler bearings
You may have to use the left-handed monkey wrench to remove the exhaust.
Old 08-31-2006, 07:05 PM
There is actually a small grease fitting located on the top of the muffler that needs to be greased. They never do it when you take it in for an oil change and lube because the exhaust and muffler needs to be removed to get at the fitting. I'd try that first before you get a whole new exhaust...
'04 H2
'07 Vette
Old 08-31-2006, 07:07 PM
tomp's Avatar
tomp tomp is offline
Mine broke off while wheeling
Old 08-31-2006, 07:21 PM
it requires the 90 degree elbow zerk
Old 08-31-2006, 07:35 PM
tomp's Avatar
That's a better idea than flipping over the muffler and exposing it like I did.
Old 08-31-2006, 09:48 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Is that due to the incompatibility of the stock zerk and the Fabtech tie-rods?
Old 08-31-2006, 10:07 PM
Yes. Plus he has the Tornado thingy, too. He's in trouble.
Old 08-31-2006, 10:12 PM
Yep, I learned, you need to put in the elbow fitting THEN grease the muffler THEN slide the tornado thingy into the tailpipe. Sliding in dry is a bad deal
Old 08-31-2006, 10:19 PM
I just use saliva...are we still talking about the muffler bearings?
'04 H2
'07 Vette
Old 08-31-2006, 10:23 PM
Star Jones's Avatar
Star Jones Star Jones is offline
Star Jones is on a distinguished road
Do iz need ta ax fagy Al to chang minz? Hez gotn time cuz he dont liks mi phat azz meat walet no how.
I wuz band frum da View. Barbar cracka-head Waters didit two me.
Old 09-01-2006, 04:29 AM
MUD4ME's Avatar
MUD4ME MUD4ME is offline
MUD4ME is on a distinguished road
I had to replace mine! I also changed the blinker fluid just to be safe....
Old 09-01-2006, 04:41 AM
YES!
Old 09-01-2006, 05:50 AM
Vettster Vettster is offline
Default Man! Don't you know nothing?
Turn the friggin radio up.
Then, you won't hear the freakin muffler bearings.
Old 09-01-2006, 03:17 PM
Motohead's Avatar
Motohead Motohead is offline
I hope you switched to halogen fluid when you did the change...
