Old 03-29-2006, 01:53 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
As a few of you may know, I recently discoverd I had a cracked block. well I purchased a remanufactured long block for the replacement.(cost around $5000). while I was removing all the parts from the othere engine for the tranplant i removed the small return hoses for the injectors. Thinking that I would just go to my local dealer and get a new set, I threw the old ones out. apon enquireing about replacements I was informed by my local dealer in Columbus Ohio that they were $13+ each, my local GM dealer could get the same for $11+ each, and I neede to replace all 8. Well to cut a long story short I found a supplier online who for the paultry sum of $44 sold me 25ft of the same hose. as I only need about 3ft I have some spair. They also have all the replacement lines from the Injector pump if you need them.
There contact info is as follows
Dipaco, inc
105 Easr Parr Boulivard
Reno, NV 89512
775-329-7511
Old 03-30-2006, 06:29 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
nice!Thanks for the info!
