Old 09-19-2006, 02:10 PM
Hummerguy04 Hummerguy04 is offline
Hummerguy04 is off the scale
Default DRL Question
Hey Guys, I have just purchased a 2006 H3 and I have noticed that my headlights are on as my DRL's. All the other H3's I have seen use the parking lights as the DRL's, however I did see one yesterday that had the headlights on as the DRL's. I read the manual and it didn't specify as to which lights should be on as DRL's, but I did read that by using the key switch and the keyless entry remote you can select different alarm warning feedbacks and other such options so I was curious if there is a way to specify which lights run as the DRL's. If not why does mine use the headlights and most all others I have seen use the parking lights? Any help would be greatly appreciated. Thanks, Scott.
