Old 09-19-2006, 09:57 PM
rocketw19's Avatar
Default need help with dash removel
im stuck on the passanger side where you have the hold on bar just over the front air bag. how in the hell does that come off? im about to break the damm thing.
Old 09-19-2006, 11:01 PM
zeros zeros is offline
zeros is off the scale
Default Re: need help with dash removel
their are 2 little white buttons you have to push in one on each side ,you have to use a long screw driver to reack the one close to the door.you have to remove the side pannel to reach the one close to the door and the other you have to reach up though the glove compartment.. someone on here had a diagram its hard to explain without pics.. it is kinda a pain to get to them.. good luck..
Old 09-19-2006, 11:10 PM
rocketw19's Avatar
ok thanks i will look for the white buttons and if i cant figure it out i will search for the thread with pics! you should of seen me yankin and screamin at that damm dash board.
Old 09-20-2006, 12:09 AM
Are you getting one of those new dashes? If so, post pics ASAP!!!
Old 09-20-2006, 12:33 AM
rocketw19's Avatar
no im just finally puttin in my LE carbon fiber dash that i have had sittin around. i should of just sold it. i still cant figure out the grab handle. i got the side thats next to the door but not the side by the radio. does anyone know the thread the pics were in? thanks
Old 09-20-2006, 12:51 AM
PM this guy:
http://www.elcovaforums.com/forums/member.php?u=562
Also look here:
http://www.elcovaforums.com/forums/s...searchid=30362
Old 09-20-2006, 12:54 AM
rocketw19's Avatar
thanks ken found the thread zeros actully started it and paragon posted some pics hopefully i can figure it out this time.
Old 09-20-2006, 01:00 AM
rocketw19's Avatar
shiiit didnt work maybe you guys had 05 or something i have 06 and the picture dosnt make sence. the out side worked fine but the inside isnt there. im gonna PM paragon and if he cant help im takin a hack saw to it.
Old 09-20-2006, 02:49 AM
HummBob's Avatar
HummBob HummBob is offline
Ken, THIS GUY paid the STEELERSHIP to change out my dash
And your 2nd LINK, NO WORKY
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 09-20-2006, 03:08 AM
SUT NEIL SUT NEIL is offline
SUT NEIL is on a distinguished road
For written instructions and a diagram refer to a post from Paragon dated
05-25-06 that he wrote in response to a thread titled how to take apart dash????
Hope this helps!
2005 SUT: Firemist Red/Ebony; LUX; Sunroof; Uplevel Chrome Pkg; NAV; Air Suspension; Remote Start; Superchip; Volant CAI & MAF; 2006 Chrome SE Wheels & Front Brushguard; Front & Rear Cameras & Park Sensors With Audible Alarms & Digital Displays; Custom Tiger Stripe Interior Panels & Steering Wheel By OEMDASH; Bassani SS Exhaust; Wet Okole Seat Covers; Defenderworx Chrome Billet Tow Loops & Side Air Vents; HotShot System
1970 Pontiac Trans AM
2000 Mercedes SL500 AMG Sport
2006 C280 4Matic
Old 09-20-2006, 04:46 AM
Instrument Panel (I/P) Assist Handle Replacement
Removal Procedure
  1. Remove the passenger I/P (Instrument Panel) side trim panel. Fully open the I/P storage compartment.
    Important
    Both the left and the right assist handle release buttons face the outside of the vehicle. The release buttons need to be pushed towards the inside of the vehicle to release the assist handle.
    Using a long flat-bladed tool, through the opening in the I/P retainer (1) on the passenger side of the I/P:
    1. Push in on the assist handle release button (2) and
    2. Pull out on the handle to partially disengage the assist handle.
    Using a flat-bladed tool, through the I/P storage compartment opening, push in on the inboard assist handle release button (3).
  2. Remove the I/P assist handle.
Attached Imageshttp://www.elcovaforums.com/forums/attachment.php?attachmentid=21330&stc=1&d=11485842 55
It sounds as though you are there. Just take a long flat bladed screw driver and there is a slot from the outside that you can see into the metal rod that the handle is made to. There is a little metal clip type retainer that simply needs to be pushed lightly towards the driver's side.
Same thing on the inboard one but I think you have to come at it from inside the glove box area. You push in on the little white button thingys and pull out on the bar and work it out
Old 09-20-2006, 06:05 AM
rocketw19's Avatar
Hope this helps!
neil do you post over at mbworld? i just picked up a e55 and found that place.
paragon thanks for your time i will look again in the morning but there is no more lil white pices to push like on the door side.
Old 09-20-2006, 07:58 PM
rocketw19's Avatar
thanks guys for your help finaly found it and finished the job now all i need is the hot shot window washer button cuzz i have a hole over there. lol thanks again guys
