09-22-2006, 06:02 PM
Key and Remote
I lost one how much for a replacement Key and remote? Can you order a "programmable" remote.
GAS
 400kts is Great, but HUMMER at 70 is better.
09-22-2006, 06:38 PM
Re: Key and Remote
I would check ebay for the fob and a blank key. The dealerships charge way too much....The fob is easy to program for the vehicle. Any locksmith should be able to cut the key...
'03 H2
09-22-2006, 07:33 PM
Re: Key and Remote
I got a key cut by the dealership the other day. Total $13.00. As far as the remote I brought one with me and was programmed for free.
2005 Slate Blue H2
09-22-2006, 08:55 PM
Re: Key and Remote
I had to get a new fob this summer at the dealer and it was $75. Programmed at no charge.
09-22-2006, 08:59 PM
Re: Key and Remote
Quick search on ebay shows key and fob for for about $18 bucks plus shipping. Programming the FOB is a piece of cake, and getting it cut shouldn't be too much...
'03 H2
09-22-2006, 09:43 PM
Re: Key and Remote
Yes it is really easy. If I work at Tustin Hummer I can even make a copy of your key while it is being serviced.Then come and steal your H2. Oh wait that already happened.
09-22-2006, 09:51 PM
Re: Key and Remote
I got a remote fob off of ebay for $12. Programming is a breeze, it only takes a couple minutes.
2008 H3 Alpha - Boulder Gray
09-22-2006, 10:58 PM
Re: Key and Remote
plain keys are about 8 bucks, 56 if they are the HUMMER keys
09-23-2006, 07:15 PM
Re: Key and Remote
Important
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
09-23-2006, 07:21 PM
Re: Key and Remote
WOW, thanks. I thought they had to be done with the "Tech tool". Will try this right away
09-23-2006, 08:47 PM
Re: Key and Remote
You guys are fantastic. I tell you I have been getting ripped off by dealers for years, this is the first time I have taken an active interest in auto forums for tips and advice and its great.
GAS
Hybrid Mode
