Old 09-23-2006, 06:42 PM
pablla4 pablla4 is offline
pablla4 is off the scale
Default sub and amp question?
i have a rockford p8002 and i was wondering if it could power 2 eclipse sw8200 subs? i dont know much bout how the amps could handle the subs or not
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id =20&item_id=27698&locale=en_US
http://www.eclipse-web.com/sw8000/sw8200.html
Old 09-23-2006, 07:04 PM
Default Re: sub and amp question?
Go to the support page and post a inquiry!!
Old 09-24-2006, 03:30 AM
Cal Cal is offline
Cal is off the scale
You can power both subs with that amp. However, the subs are going to be underpowered, and the amp is going to be working very had. The specs for that amp are 200x2 @ 4ohms or 400x2 @ 2ohms, and the sub is 670 @ 4ohms. That means if you hook them up to that amp at 4ohms(Recommended) you will only be sending 200 watts to each sub. I believe you can do 2ohms as well, which would give you 400 to each sub. It would not be the best for the amp, but it is do able. Now if you decided to go with just 1 sub(what i would do) you could bridge the amp and get 800 watts @ 4ohms, which would be more than enough to power that sub to its full potential, and now overwork the amp at all. 1 sub would give you all the bass you could ever ask for, as long as the sub is given its recommended air space in a properly build box. I was looking around for a minute on the site to see what type of box them recommended(Sealed, Ported, Bandpass, etc) but could not find it. I hope that helps a little.
-2006 VR Hummer H3 Lux/Off Road
-2003 H1 Black Wagon(sold )
-2003 H2 Black lux (sold)
