Old 09-11-2003, 12:56 AM
unaslob unaslob is offline
unaslob is off the scale
I am trying to remove the center dash so that I can get to the back of the radio. I thought it would be easy, remove a couple of bolts, and wham...done in an hour. well an hour later, I screwed the alan bolts back in, and gave up.. any hints...
Old 09-11-2003, 03:35 AM
PAC PAC is offline
PAC is off the scale
The center console has to be moved back a little. The shift lever has an allen screw tha needs to be loosen to remove the knob. You have to access the pocket in the center console to remove some 10mm bolts. And the long a$$ allen screws that are near the top of radio bezel, that look like they hold the engine in, need to be removed. The rest is easy.
Karl
www.pac-audio.com
Karl
www.pac-audio.com
Old 09-11-2003, 02:24 PM
HappyJack HappyJack is offline
HappyJack is off the scale
Please see this post.
procedure post
Cheers
[ formerly known as wannabe and wannabeinit ]
Cheers
