Old 10-03-2006, 09:07 PM
H3.007 H3.007 is offline
Default Passenger Door Sill Rattle
Has anyone experienced a rattle near their H3's passenger door? The rattle in mine is eminating from under the plastic sill cover and it almost sounds like a loose nut or pebble inside, sliding back and forth during hard braking and acceleration. How does the plate detach from the metal portion of the seal? Perhaps I can locate the item making the noise to let everyone know in the event this is a common, unresolved issue.
Old 10-03-2006, 10:16 PM
fourfourto's Avatar
Default Re: Passenger Door Sill Rattle
My wife told me theres a rattle in passanger door.
I checked it out it was my sunglasses.
Sorry im no help I thought it was funny
Old 10-04-2006, 01:20 AM
- I thought the same thing, regarding a foreign object of possession. Unfortunately, it wasn't that easy....
Old 10-10-2006, 02:56 AM
I had a friend at a garage pull the sill plate for me today (he knew where the clips were). We foudn nothing- and the noise is still eminating from that area. Could it be something in the frame or rocker that has come loose?
Old 10-10-2006, 10:40 AM
Could be something in there. If it sounds metallic, run a magnet back and forth and see if you can hear it sliding. If so, take it to one of the holes and try and get out.
If too large, spray a little foam on it to hold in place, or take it to the dealer.
Old 10-10-2006, 01:17 PM
Thanks f5! I'll try that. To me, it sounds like a screw or perhaps a small nut...
Old 10-10-2006, 09:32 PM
Neat idea - I never thought of this!
