Old 10-03-2006, 11:22 PM
Lex_Ordo
Default Removing Sun Visor
I was hoping someone could tell me if it is easy as removing the screws or a little more involved.
I don't like taking things apart when I don't know what other fasteners might be in the way.
I have a small piece of plastic floating around inside there that needs a good shake to get out.
The passenger side had the same issue. Appears to be a small bit of the pull out sun visor tab. Nothing crucial by any means, just annoying to hear. The passenger side just came out when I pulled the slider out. That problem fixed itself, but the driver's side has not had as quick a fix.
Looks like the three bracket screws just unscrew out of the roof assembly, and the whole visor will be free. Anyone from GM no better?
Old 10-04-2006, 12:46 AM
Default Re: Removing Sun Visor
If you have the sunvisor with the three buttons for garage door, there is also a small connnector, but other than that, just remove the screws.
Old 10-04-2006, 02:57 AM
Lex_Ordo
Thumbs up Re: Removing Sun Visor
Thanks. No garage door opener, so it should be a quick 1...2...3...
Edit: Took all of about 10 minutes start to finish.
