Old 10-04-2006, 11:02 PM
Default Bank Window Drama
Whats the solution other than going in the bank to the window problem on the slab sided H3? I tried opening the door and reaching back. Thats not doing it either.
Old 10-04-2006, 11:17 PM
Default Re: Bank Window Drama
Invite the banker to your house? What is the window problem in a slab sided h3?
Old 10-04-2006, 11:43 PM
no dice and the atm's are too low , i just park and walk up
Old 10-04-2006, 11:49 PM
I pull up to the drive through and get out.
Old 10-05-2006, 01:50 AM
LOL
Old 10-04-2006, 11:53 PM
I am glad to be drive through free at the bank.......good god those tellers are hot and got the assets to back it up!!!!! Not to mention, better views of the assets!!!!!
Old 10-05-2006, 12:06 AM
I deal with 2 different banks and have no problems in the drive through
RYD
Old 10-05-2006, 12:10 AM
Heehee, I've been going into the bank for years just for that purpose.
Old 10-05-2006, 12:22 AM
Desert Dan's Avatar
No Problems at the ATM.
All the money has gone into the H3
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-05-2006, 12:30 AM
Viet Nam Vette's Avatar
My Banks dirve up teller is an idiot..!!! A few years back I followed my buddy to the bank. I needed to do an ATM and he needed to go thru the drive thru teller commercial side.
As he drove up in his 4X4 F250 Crew Cab and the A hole Teller opened the sliding drawer where you place your deposite. The timing was perfect...use your ""imagination""..!!
He ripped that sucker right off the bank teller wall..!!!
The bank paid to fix is rig...Bricks all over the place ...Freaken funny.
Old 10-05-2006, 12:33 AM
You know the pill box look. Small windows straight sides. Do you own a H3?
Old 10-05-2006, 12:35 AM
Originally Posted by wpage
Do you own a H3?
Do you?
Old 10-05-2006, 12:40 AM
Is dementia a family trait, or did it just start with you?
If you used just a WEE bit of common sense before you made the idiotic comments, you would realize that you have it backwards. The "slab sides" would actually make it easier at drive-thrus, such as teller windows and ATMs.
Since the common vehicle angles toward the roofline, it causes the driver to have to move further from the window/ATM and then reach FARTHER. The flat sides obviously puts the body of the driver closer to the window/ATM. Now, if the height of the window is the issue, raise your seat a little, sorta the same idea as the lifts you put in your shoes.
Old 10-05-2006, 01:35 AM
Have you ever actually attempted to reach an ATM or Toll Ticket machine from the H3's driver's seat? It's a chore, even if you unbuckle and stand up. The contortion of the arm probably looks amusing to bystanders!
Old 10-05-2006, 01:56 AM
Have you ever actually attempted to reach an ATM or Toll Ticket machine from the H3's driver's seat? It's a chore....
maybe you should work out more
Old 10-05-2006, 02:02 AM
Have you ever actually attempted to reach an ATM or Toll Ticket machine from the H3's driver's seat? It's a chore, even if you unbuckle and stand up. The controtion of the arm probably looks amusing to bystanders!
Wow, how often do you unbuckle, stand up in your H3 and reach for the ATM? Do you have pedal extenders?
Let's assume you meant contortion, when you said "controtion." Why would one need to contort one's arm to stick it straight out the window? Oh, nevermind, I forgot. Your head consists of an orgy of stultifying cacophonous mental depravity; an exercise in intelligent impotence, and an offense to retardation.
Old 10-05-2006, 01:47 AM
Lex_Ordo
E-Z Pass, for tolls.
Park and walk up, or walk inside for ATM.
