10-05-2006, 05:00 AM
Anyone else 06 sunroof do this?
The express open feature works most of the way, then stops and I have to push the button again. Is this normal? I could understand if it did this when you closed it, but why does it do it only when it's opening?
10-05-2006, 05:22 AM
Re: Anyone else 06 sunroof do this?
Mine does the same thing. And when I close it, I have to push it again to make sure it locks up into the proper position.
10-05-2006, 05:29 AM
I think they all do this.
06 Adv. nuff said
10-05-2006, 05:34 AM
Add mine to the list.
And I thought I was doing something wrong.
10-05-2006, 08:42 AM
Mine does it too. Closes tight though
MINE - 2006 H2 SUT
10-05-2006, 12:03 PM
I think it is right when you open it. That is because 2/3 open does not allow the air to flow in freely and cause the flapping sound to be produced. But closing should go in all the way with one touch of the button.
Thanks!
10-05-2006, 01:13 PM
Same on the '05 so it's normal. But ours closes all the way.
10-06-2006, 01:35 AM
normal operation of the sunroof is to one touch open about 90% of the way....if you want it full open, hit the button once more.....should go closed completely with one touch....
2009 H2 Silver Ice LE
10-06-2006, 03:25 AM
normal 2 position open deal
10-06-2006, 08:36 PM
 My 06' does the same thing, I think its for wind noise on opening only. As said before closing is one step though.
Not to hijack this post, but does your sunroof deflector make noise over 75 mph. Mine starts howling, I think it was to do with the lightbar though?
10-06-2006, 08:47 PM
I took mine off becasue of this. You have to bend those two brackets to make it push down harder onto the roof of the truck but than you risk casuing issues of your sunroof leaking. That happend on my SUT. So this truck has no deflector. The GOBI fairing takes care of that though.
10-07-2006, 02:45 AM
What he said. That is exactly how it was described to me by the dealer, just prior to me driving away in my new '06.
10-07-2006, 03:36 AM
idunno, I drive 85-90mph  and I like to have my music loud!
Try removing the light bar and see if it makes a difference...if not...the radio is your friend!
10-07-2006, 04:45 AM
Have you had the infamous windshield pillar trim pieces fixed or replaced? Most wind noise problems seem to come from these. I had the dealership fix mine.
10-07-2006, 05:26 AM
Concerning the wind noise, I thought it waws going to blow off {the deflector on top} so I removed it coated the rubber seal at the bottom with clear RTV silicone and reinstalled with 2 stainless screws and nuts as opposed to those ugly sheetmetal screws on my 2006 H2. No more noise.
H2 REBEL lennyrebel
10-09-2006, 05:15 AM
Tell me more about the trim pieces. Which ones are you talking about? What is the "fix" for them? Thanks.
10-09-2006, 05:57 AM
I see I am not the only one with some goofy noise coming from what appears to be the sunroof air deflector at speeds of 80+
Is there a good fix for this?? I tend to drive my hummer as if it were a ferrari on the highway, and that damn air noise is pretty annoying!!
Carless... riding the bus...  Trying to decide on which 08 H2 to get
10-09-2006, 12:19 PM
Happened to me too. Sometimes (very rare), when I close it, the last inches, I have to push the button again and again to get it completely closed.
10-16-2006, 04:23 PM
Mines does this. Weird cuase i always check if theres something impededing its course to close, and theres nothing.
Black 05 Hummer H2. (STILL WORKING ON IT!)
10-17-2006, 07:22 AM
Hi Guys,
there is actual Bulletin about this problem , and dealer knows about it
Document ID# 1844364
Subject: Sunroof Timing Procedure - keywords alignment body installation learn roof sun switch #PIT4065 - (06/27/2006)
