Old 08-30-2003, 04:10 PM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
I am installing my Gibson headers and the instructions say to use the "stock O-Ring gaskets" between the headers' collector pipe flange and the Y-Pipe flange. I did not see any type of gasket in this location.
Did you have a gasket between your stock exhaust manifold and the Y-Pipe? If not did you just bolt the two flanges together? Any leaks at this joint?
Old 08-30-2003, 10:03 PM
TMKHUM TMKHUM is offline
TMKHUM is off the scale
There is no o-ring.
There should be a triangular gasket with a 3 hole pattern and center cutout for the exhaust pass thru.
Generally its best to order some factory GM gaskets as the headers generally come with crappy gaskets.
Tom
Old 08-31-2003, 02:06 AM
Thanks TMKHUM
Upon closer inspection with a light I noticed the O-Ring is seated inside the Y-Pipe flange. I bolted the two flanges together and after starting did not find any leaks. Time will tell.
Old 08-31-2003, 02:33 AM
GM must have changed there flange seal. I put a set of shorties on my Trans am (aluminum 5.7 liter variant of our 6.0 liter motor) and they utilized the gasket I mentioned. I guess they must have switched up to o-ring donut seal along the way.
By the way what type of gasket was on the exhaust manifold to cylinder head? On the LS1, I have typically seen a 2-layer metal gasket used...pretty good stuff...especially coming from the factory.
Tom
Old 08-31-2003, 02:42 AM
It was a three layer metal gasket.
