Old 10-09-2006, 06:25 AM
Default What's the name of this part?
What's the name of this part so I can replace it, I busted them on both sides.
It looks like one big piece in the wheel well, but is it the wheelhouse assy, fender liner or what?
Old 10-09-2006, 06:54 AM
westhillsat's Avatar
Default Re: What's the name of this part?
How did you do that Dei
Old 10-09-2006, 09:14 AM
Nefarious Nefarious is offline
Nefarious is an unknown quantity at this point
It's a fender liner and not absolutely needed unless you just want to help keep things clean by blocking stuff that is thrown off the tires.
Old 10-09-2006, 10:55 AM
I would say the right one is required, the air inlet is under it, toward the top, and helps to prevent water from getting in the intake.
How did you break them? They are somewhat flexible.
Actual part name could be a fender or wheelhouse liner. Service manual call it a Wheelhouse Panel, and procedures names are supposed to be similar to part names; not always like that.
It won't be cheap. If the only damage is that crack than I would repair it with some flexible repair material.
Old 10-09-2006, 03:35 PM
I'm guessing I had the tires turned when I hit a bump while offroading. If they still can't reach that part, then I don't know how it happened.
I'd rather replace them anyways, I like it to keep it clean when I can.
On alldiscountparts.com, they have fender liners for $35/ea, then wheelhouse assy's for $130/ea. Their illustration doesn't show up for me though.
Old 10-09-2006, 03:47 PM
partsguy partsguy is offline
Buy the liner,The wheelhouse is the sheet metal behind the liner.
Old 10-09-2006, 04:55 PM
True, procedure is incorrect. The rear is called:
LINER,RR W/H PNL. Why can't I find a front one listed in the PBS site?
Old 10-09-2006, 10:27 PM
thanks. It's only listed on the trademotion sites as fender > inner components > fender liner, with left and right side, but it doesn't specify if it's for the front or rear. I just emailed them about it, so hopefully that's cleared up.
Old 10-09-2006, 11:44 PM
For my future reference...
LF fender liner - p/n 15859542; new p/n 15832721
RF fender liner - p/n 15859543; new p/n 15859542
Old 10-10-2006, 09:38 PM
Interim solution black duct tape
