10-11-2006, 01:07 PM
what do I need to mount my front license plate on my H3?
Just got my plates today. There are 2 square holes up front but no bracket or any threaded inserts for bolts or anything.
Is there some sort of bracket for it?
10-11-2006, 02:22 PM
Re: what do I need to mount my front license plate on my H3?
check in your glovebox and see if there are two small plastic plugs -- those pop in those holes, then you can use screws (which may be in there too) to attach the plate..if not -- your dealer probably has a ton of these and would just give a couple to you.
10-11-2006, 02:31 PM
ah I will check that out. Probably the same as the ones for the back plate.
thanks
10-11-2006, 04:40 PM
You can also get them from any auto parts store!
10-11-2006, 04:48 PM
no luck in the glovebox.
looks like a stop at AutoZone
10-13-2006, 02:29 PM
Advance Auto sells these plugs. I remove my dealer vanity plate and plugged the holes with the plugs. They are very large in size. The shaft is about 3/8" OD , 1.5" long, and the cap is about the size of a half dollar. They look like black, streamlined mushrooms.
10-13-2006, 02:44 PM
OR.........
SUPER GLUE !!!!!
RYD
10-13-2006, 03:42 PM
[quote=RubHer Yellow Ducky] OR.........
SUPER GLUE !!!!!
RYD[/quote
I prefer "Duck Tape" or is it "Duct Tape?"
10-13-2006, 03:54 PM
[quote=timgco]
OR.........
SUPER GLUE !!!!!
RYD[/quote
DUCKY TAPE
10-16-2006, 09:26 PM
Well I went to AutoZone and they had a plate mounting kit for $0.99. It has 4 screws and 4 square nylon plugs that are threaded on the inside. Used two of them, they snapped right in the bumper and the plate screwed right on!
10-16-2006, 09:35 PM
cool
10-16-2006, 10:00 PM
AUH !!!
What I would give for some $ .99 cent screws...
RYD
10-17-2006, 02:41 AM
QUACK (tape)
Any fix for a buck is a good fix!!!
10-17-2006, 04:08 AM
You should have had the dealer provide them and put them in, if the state you are in requires plates on the front and back - then it's the dealers responsibility to make the vehicle plate ready.
10-17-2006, 04:48 AM
If your going offroad, bend the plate to the bumper and put in 4 screws. Might save the plate
10-17-2006, 06:13 AM
AUH !!!
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
10-17-2006, 03:41 PM
I didnt realize that it didnt have mounting provisions until I received the plates. also, I got the vehicle in Ohio and I now live in North Carolina so it was just easier this way
True
