Old 10-15-2006, 06:55 PM
Wisha Haddan H3's Avatar
Default Couple of new toys
Ordered a set of Staun tire deflators and no-loss NATO valve caps on Friday. Wheeling season is slowing down, but they may come in handy in the snow
Got the deflators off ebay for $55 shipped from down under. http://search.stores.ebay.com/Wild-Earth-Australia_staun_W0QQfciZQ2d1QQfclZ4QQfsnZWildQ20Ea rthQ20AustraliaQQfsooZ1QQfsopZ1QQftsZ2QQsaselZ1044 20875QQsofpZ0
The valve caps are from Mesa 4x4. $15 out the door and mailed the next day
http://www.mesa4x4.com/dynamic/part_...num=EO-008-001
Also got a portable CB from Midland (model 75-822). It was only $85 on sale at Walmart but has 40 channels (plus weather) and 3 power packs for battery or car use.
http://www.midlandradio.com/comersus...idProduct=3108
Old 10-15-2006, 07:03 PM
Default Re: Couple of new toys
Sweet!!
Old 10-15-2006, 09:24 PM
CB is cool, thinking of getting one, and I like the mobile hookup kit they offer for only 30 bucks more.
Old 10-15-2006, 11:35 PM
The mobile power adapter is included! Guess they list it separate so you can get one for a 2nd vehicle.
Old 10-16-2006, 12:19 AM
fourfourto's Avatar
I got both of those.They work great
Remember to check setting on deflaters I have them at 18psi.
One or two were a little off when I received them.
The deflaters are one of the few things that will fit in the door pockets.
Old 10-16-2006, 12:00 PM
I Bought that portable CB last year. Its a good unit. Broken down it fits nice in the console area. Lesson learned on it was the rechargable batteries get tired and need a good charge up B4 using or transmission is weak. Its a 3watt max to begin with and the 12v integrated plug in takes a while to bring it up to speed unless you use it frequently.
Old 10-16-2006, 01:35 PM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
Nice toys love those vavle stem cover good idea.
Old 10-16-2006, 02:56 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
I've got that Midland.. If you're going to use it with the car adapter you're going to have to mount an external antenna.. You can' power it from a cig plug and use the rubber BNC antenna..
I mounted a Firestik Firefly 4ft on the roof with a flip over mount and am keying an SWR of 1.1 (ch1) - 1.4 (ch40).. Range isn't but maybe 3 miles talking in town, but a 100 watt linear could be hooked in for $100 or so and stretch that on out to 10-15 miles out in the open..
I think Sewie has pics on his website of this antenna setup that he used on a Cobra handheld...
Rob
I went with the Midland because it can be used as a portable radio to walk around with if needed..
Old 10-16-2006, 04:38 PM
I have a six foot red/white/blue firestick from my Jeep that I could use. Has me thinking.....
Old 10-16-2006, 04:56 PM
Weird, the manual says you can use the attached antenna (with limited range), but I was going to look into an external mount anyway.
Old 11-15-2006, 11:07 PM
SR1355's Avatar
SR1355 SR1355 is offline
So how do you like the Staun Tire Deflators, I'm thinging off getting a set and adding them to "What do you carry in your cargo door jack compartment".
Paul M
SR1355
Old 11-15-2006, 11:42 PM
Haven't used the deflators yet, but they look solid. One of these days I'll have to try them out. They're factory pre-set to 18 psi, but you're supposed to double-check the pressure.
But the NATO valve caps are awesome. Got really cold here recently and I had to top off my tires. It was nice not taking the gloves off to handle the caps, dropping them when my fingers go numb and fishing them out of the snow. Definitely worth the $10. The threads seat well too ... high quality.
Old 11-15-2006, 11:57 PM
SR1355's Avatar
Thanks, I think I'll pick up both.
Paul M
SR1355
Old 11-16-2006, 12:37 AM
They definitely make it easier/quicker to air down. But you should check the setting on them fairly often as they tend to "adjust" themselves pretty easily.
Old 11-16-2006, 12:53 AM
SR1355's Avatar
Thanks for the advice, I sure hate to air down to far and lose a bead.
Paul M
SR1355
Old 11-16-2006, 01:24 AM
You can use it with the stock (integrated antenae) just watch the squelch or it will fail. Range is about 3 miles line of sight.
Old 11-16-2006, 03:59 AM
westhillsat's Avatar
I have the same deflators from the same place and the same cb, but paid more Love both of them
Old 11-16-2006, 04:01 AM
Neo put black marker lines on his to tell if they turn from where he wanted them set
I still need to do that
Old 11-16-2006, 04:31 AM
Crash ?'s Avatar
hhmmm.. Makes me wonder why mine won't.. I wound the squelch all the way up and down and got nothing out of it.. May have to do some expirimenting this weekend and see what's up with the thing...
Rob
Old 11-16-2006, 04:01 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
I have that CB. It works GREAT!! I had a local CB shop connect a 4' Wilson fiberglass anenna to the rear bumber. I ran the cable up throught the truck and under the drivers seat and into the center console. Attached the wire to the external adapter on the CB and plugged the power in to the dash.
i recently used it on a trip with my club to the badlands. everone was asking me about my radio and could not believe that my simple little set up that tucks away in my center console sounded better than anyone! I was very pleased and the total cost of my set up was just under $150. I also bought my CB at Wal Mart.
I highly reccomend this.
____________________________
