Old 10-16-2006, 05:22 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Exclamation What does it sound like when the rear diff goes?
I was getting ready to go on a great day of wheeling this past Sunday...When I started the rig up the service engine light and Stbilitrack failure light came on and the whole truck started to wobble or vibrate. As I drove around the block it seemed as if the RPM were running low and that some sort of binding (grinding) or lurching was present in the rear of the vehicle. I didn't take it offroad that sunday and started her up this morning and everything was normal. WTF...HELP...Going to the dealer this afternoon. The H3 is exactly 1 year old to this month and has about 18,500 miles on it. What does it sound like to you guys?
The Goat
Old 10-16-2006, 07:30 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: What does it sound like when the rear diff goes?
It may have started up under low power and that could explain some weird performance. Good news is that it doesn't sound like a diff because it went away...the diff would be constant and probably getting worse.
-Brian
http://www.hummerguy.net
Old 10-16-2006, 07:33 PM
Sounds to me like you have a hitch in your git-a-long
Old 10-16-2006, 09:46 PM
X2
busted diffs dont go away i wish they would
Old 10-16-2006, 09:57 PM
Is that like a pair of socks in your crouch ???
RYD
Old 10-16-2006, 10:01 PM
Mark805's Avatar
Mark805 Mark805 is offline
Mark805 is off the scale
the engine and low power sound exactly like the problem i had after returning from a 3week vavcation. Did the DIC display "reduced power" message at all?
Mine did and was running rough and barely moving down the roar.
Once the battery was charged it all went away.
08 H3 ALPHA Carbon Black
Dear GM: PLEASE SELL ME AN HX
Old 10-16-2006, 10:24 PM
Is that like a pair of socks in your crotch ???
RYD
That an old Rock Star trick that I would know nothing about
Old 10-16-2006, 10:28 PM
TUBE socks work best !!!
RYD
i thought you knew a bunch of old rock stars
Old 10-16-2006, 10:45 PM
The Rock Cock Collection.....
Old 10-16-2006, 11:56 PM
Did you call Onstar, they can tell you the codes. Reduced engine power would not come on due to busted diff, unless it was locking up the drivetrain, and then I'm not sure if that message would be displayed. I'll be curious as to what the dealers says. If it is a p300+ code, it might be a cylinder head.
Old 10-17-2006, 01:20 AM
Originally Posted by NEOCON1
X2
In H3s busted diffs just keep coming and coming and coming
It's either the dicks that can't drive them or the shitty the vehicle, in your case I guess it's both
Old 10-17-2006, 01:30 AM
Sorry it's the sh1tty differential....WTF is your problem??? Do you need a sammich????
Old 10-17-2006, 01:33 AM
another sad attempt
Old 10-17-2006, 01:49 AM
There seems to be certain dick H3 owners that have gotten a little full of themselves and mouthed just a wee bit too much in the wrong direction.
Neo is now going to be my little bitch for a while and other H3 owners are going to get all butthurt because he doesn't know when to shut his yap.
Old 10-17-2006, 01:54 AM
my a$$ is tough , you still sound retarded
Old 10-17-2006, 01:55 AM
theres no room he already has a d1ck in his mouth
Old 10-17-2006, 02:00 AM
...all messin around aside.
Once you here the sound of the key going into the ignition and engine starting and shifting into drive, everything will sound normal for the first few feet. Next you usually here the owner of the H3 screeming bad words that ryme with words like spit and duck.
You will here some groaning back there/ possible grinding.
Old 10-17-2006, 02:29 AM
Am I reading this wrong
OR
Do you have a mental problem !!!
RYD
Old 10-17-2006, 02:38 AM
H3.007 H3.007 is offline
H3.007 doesn't need socks in the crotch
