Old 10-18-2006, 04:11 AM
Default new wheels
How do you like my new wheels
Old 10-18-2006, 04:14 AM
Default Re: new wheels
What lug nuts are those?
Old 10-18-2006, 04:33 AM
splinedrives
Old 10-18-2006, 04:49 AM
M14x1.5 right?
Old 10-18-2006, 05:34 AM
Do you have a website for them? I found some black aluminum ones on ebay, but they are open ended.
Old 10-18-2006, 02:19 PM
Hi Hummer's Avatar
Hi Hummer Hi Hummer is offline
Hi Hummer is on a distinguished road
i like those rocker guards even more. who makes them???
T&A affiliates
HOABette
Miss Sassy Pants
Old 10-18-2006, 02:28 PM
http://www.hummerproducts.com/H2%20S...ack%20Zinc.htm
Old 10-18-2006, 02:31 PM
custom job. For someone that has stock rocker guards, I can get this guy to make up something similar.
Mine aren't finished yet, though.
Old 10-18-2006, 02:36 PM
Hi Hummer's Avatar
sweet. i may want some for..............
T&A affiliates
HOABette
Miss Sassy Pants
Old 10-18-2006, 05:32 PM
Those are nice, have you bent them at all? Does your leg rub them all the time when you get in and out?
BTW, those wheels need some serious bling-age!
Old 10-18-2006, 05:40 PM
Haven't bent yet. They are used as steps and I'll have plating on top for better steps.
Old 10-18-2006, 05:54 PM
My stock rails have pushed up against the bottom of the chassis. I was just wondering if those are the stock rails, with a piece welded on the outside. (that's what it looks like) I might need something a little beefier.
Old 10-18-2006, 06:10 PM
That's all it is. I haven't needed much beefier. It's not going anywhere else and is not hurting the body.
Those stock rockers (before we welded the extensions on) are dented and bent. One of the other reasons I extended them so for is to create a better step because U-steps will no longer go on my truck since the rocker brackets are all bent.
I think the stock rockers held up better than most other parts of the underside of my truck.
Old 10-18-2006, 06:14 PM
Is that the frame?!?! How'd that happen?
I got to look at mine the other day, and it's not nearly that bad!
Old 10-18-2006, 06:33 PM
My torsion bar bracket is bent up. Driver's side is higher than PS. Cross member is just beat to heck and back. The transmission bracket is now shaped like an arch instead of being flat.
The frame itself has several spots where it is caved in. Body mount tabs are bent, etc. I'm thinking of putting the chrome back on the truck and just selling it to a blinger.
Old 10-18-2006, 06:48 PM
You'll have to put lots of chrome on it!
I feel better about how mine looks now, Thanks.
Old 10-18-2006, 08:34 PM
Alan06SUT's Avatar
Just spray it all flat black and most will never know the difference. And, if it still rides straight down the road, who cares??
Old 10-19-2006, 01:22 AM
Dug Dug is offline
Dug is off the scale
Paragon, i dont get it. What is new about your wheels?
Old 10-19-2006, 02:21 AM
I painted them. They used to be black.
Old 10-19-2006, 02:57 AM
Dug Dug is offline
ok
