Old 10-18-2006, 11:36 PM
apexer apexer is offline
apexer is on a distinguished road
Default H2 steering
love my H2 ,its a 2005,with 22000 miles. The steering seems to be a bit loose,little bit of wondering,checked tires,OK,steering wheel sits straight,no pulling.Compared to my 2004 F150 4+4,seems a bit sloopy,any ideas?,or is this normal.
Old 10-19-2006, 01:08 AM
Dug Dug is offline
Dug is off the scale
Default Re: H2 steering
Are the tires wearing in any other form than ever all the way across? Could need a front end alignment.
Is there alot of play just in the wheel when its parked , Could take some slack out of the gearing box with a small adjustment.
This also has alot larger tires than your f150. Maybe you'll get used to it.? Are tires inflated to the right pressure?
Old 10-19-2006, 03:48 AM
Vettster Vettster is offline
What about tire pressures?
Might want to fit up a sterring stabalizer also.
