Old 10-25-2006, 12:20 PM
yat74's Avatar
yat74 yat74 is offline
yat74 is an unknown quantity at this point
Question Question about tires and stock H3
Will there be a problem if I put 35" tires on the truck if it does NOT have the Offroad package with the rear diff locker?
The Goat
Old 10-25-2006, 03:52 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: Question about tires and stock H3
The problems that arise (possible rubbing, although there's many who have 35s that don't rub, gas mileage decrease, etc) really don't have much to do with the fact they do not have the adventure package, just the pure size of the tires. Some folks put the factory 33 inch tires on a base model for example with no problem -- at least for everyday driving. Off-roading will still be better even w/out the stiffer suspension just because you have the added clearance and grip of the larger, aggressive tire...just work on your brake-throttle modulation skills to overcome the lack of a locking rear diff..
-Brian
http://www.hummerguy.net
