Old 11-01-2006, 10:13 PM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
Default Engine temperature
Just question to those who have possibly dual fans or and 160 degree t-stat. We got first snow today and temperature high 20's. My engine temperature (by the meter) will not go over 160 degrees. Does this sound right? Can it really be that driving in these conditions and with this setup, will not get engine temperature over 160 degrees after driving like 15 minutes?
Old 11-02-2006, 02:22 AM
Dug Dug is offline
Dug is off the scale
Default Re: Engine temperature
Well i dont know if the guages are exactly accurate. But you would need to know that temp range thermostat you have to know what normal is. If you have a 160 degree thermostat , yes it sounds right.
