Old 11-08-2006, 09:22 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Default Mirror swap write up.
I traded wpage my chrome mirrors for a set of black ones he had and thought I would do a write up real quick for anyone that hasn't done it. I haven't seen a how-to so here is a how-to. It wasn't NEARLY as difficult or time consuming as i thought it'd be. It took me about 20-25 minutes. Here are some quick instructions:
1) take out the 3 screws holding on the door panel. 1 is behind the door handle latch 2 are behind the grab handle trim piece.
2) pull gently from the lower corners to pop off the door panel and then lift up to get it out of the window channel.
3) roll the window down
4) unplug the harness and wire holder
5) remove the 4 screws hold in the mirror and try not to drop any, also hold the mirror through the window when taking out the last screw just to make sure it doesn't fall and scratch up your door.
6) move to the outside and pull the mirror off and then remove the rubber grommet.
7) put the new mirrors on and reverse the steps.
ALL DONE!
