Old 11-12-2006, 12:34 AM
errett errett is offline
errett is on a distinguished road
Default Changing front grille
I am wanting to change out the chrome grille on the front of my H2 for a black painted one. I am sure folks have done this, I am just wondering what it takes to get the front grille off and the new one back on.
Any help is appreciated.
E
2006 Hummer H2 Adventure - Yep it's a hybrid! - SOLD
2006 Infiniti G35 Coupe - SOLD
2005 Honda Aquatrax R-12x - SOLD
2012 Dodge Challenger SRT8
2012 BMW X5 xDrive50i
Old 11-12-2006, 03:27 AM
KrazyMedicRN's Avatar
KrazyMedicRN KrazyMedicRN is offline
KrazyMedicRN is on a distinguished road
Default Re: Changing front grille
it isn't hard ... takes about an hour if you have a brush guard
  1. remove factory brush guard should be total of 6 bolts (4 lower and 2 inside grill)
  2. Remove lower black mesh grill held on with for clips gentle pulling pressure will pull it out of chrome grill
  3. open hood and remove 4 nuts (located 2 on each side to outside of marker light housing)
  4. close hood and with gentle pulling pressure pull grill away from hood clips are the only thing holding in place
once this is done reverse process with new grill... make sure you have an assortment of sockets metric and standard will need a 15mm socket for lower brush guard these may be a little tough to get off mine had locktite applied.
hope this helps
Thanks in Advance
Rich
Picture of my 2005 H2 YELLOW SUT
http://www.myspace.com/krazymedicrn
Old 11-12-2006, 04:19 AM
Thanks for the help. I am going to get it ordered and change it out.
E
Old 11-12-2006, 06:58 AM
dochummer's Avatar
I'd say less than 15 minutes if you've done it before....
'03 H2
Old 11-12-2006, 02:47 PM
vador99 vador99 is offline
vador99 is off the scale
