Old 11-13-2006, 09:43 PM
Default Do it yourself bed-liner stuff??
Anyone know of any good do-it-yourself bed liner (non-slip) stuff to use on rock rails, racks, steps, etc? Where do ya get it?
Old 11-13-2006, 09:45 PM
Default Re: Do it yourself bed-liner stuff??
How 'bout this stuff - Herculiner?
http://www.jcwhitney.com/autoparts/I...D:100000283143
Old 11-13-2006, 09:50 PM
http://www.detailandstripes.com/tatrbedco.html
made by bondo, sprayable or you don't have to add the thinner and you can roll it. has cut up tires in it.
Old 11-13-2006, 09:55 PM
oops
Sorry, that's not what I meant. I don't know anything about that stuff.
This is what I meant to post. It's got the tires in it and can be sprayed if you mix thinner in it.
http://www.durabakbedliner.com/
BlueTJCO's Avatar
BlueTJCO BlueTJCO is offline
with the way that the "bedliner" applies and sets it will look good but on the trail you will NOT be happy.
It will "tear" and look like **** with just minor rock rubbing...
Old 11-13-2006, 10:26 PM
I know. I'm only wanting to put in on the TOP of stuff - like my rock rails. I've seen pics of how it rips off when you put it on the bottom. Hummbebe comes to mind.
Old 11-13-2006, 10:31 PM
Ummmmm...... same as paint. You touch it up same as paint also. The worst thing to do would be to powdercoat them, then you couldn't even paint over the scratches and match it up.
Durabak is very durable and doesn't peel but you would rattle can some rustoleum as a base anyway, I would think.
Old 11-13-2006, 10:53 PM
Paint just gets removed where you hit it with a rock. That line-x stuff tears in big sections.
Ummmm... Add 1 part Rubicon, 1 part Line-X. Mix, and.....
Old 11-13-2006, 09:56 PM
GLBLWARMR's Avatar
The Herculiner works great. I have used it a few different times for things. Very easy to use.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
