Old 11-14-2006, 05:52 PM
Jeff G's Avatar
Jeff G Jeff G is offline
Jeff G is off the scale
Default H3 Wheel Question
I have looked at several wheels for my H3 and have decided on a 17 X 9. The only issue I have, is how it will fit the H3. It has a backspacing of 4.53" and a -12mm offset. Does anyone out there more knowledgeable about wheels than I, know if this will fit correctly? Thanks for any help.
Jeff
Old 11-14-2006, 06:02 PM
K9sH3's Avatar
K9sH3 K9sH3 is offline
Default Re: H3 Wheel Question
You most definatley need to be sure you have the right rims. When I bought mine there where 100's to chose from, then when we narrowed it down to which one actually fit it came down to like 20. Be very carefull and buy from a referred dealer. I personally do not recomend buying off line unless you are 100% sure about it.
Old 11-14-2006, 06:44 PM
Jeff G's Avatar
Exactly!! With the cost of wheels, I need to know that they're going to fit. I just can't figure out the backspacing and offset to know if they will work.
Old 11-15-2006, 01:02 AM
Jeff G's Avatar
Does anyone on here know anything about the backspacing and offset of a wheel? And how I can tell if they will fit my H3? Thanks again.
