Old 11-21-2006, 03:37 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Talking need your help (engine cranking)
Ok, i've now blown my second engine this one with just under 8k on it. with only 39k on a 99 wagon i'm doin pretty good. so what i need to know is this. is there any way to crank the engine over from inside the engine compartment while i run a compression test on all the cylinders.
Thanks in advance Ground hwg
