Old 11-28-2006, 07:32 AM
joedirt's Avatar
joedirt joedirt is offline
joedirt is on a distinguished road
Default Removing Sport Rails
Has anyone removed the H3 factory sport rails below the door? I removed the bolt on each side in the inner fender and then pressed in the clip tabs underneath, but I still was unable to remove the sport rail. Any Suggestions?
Old 11-28-2006, 11:55 AM
Default Re: Removing Sport Rails
Sport rail? Do you mean the black plastic rocker panel, or do you have rock rails installed?
Old 11-28-2006, 10:32 PM
joedirt's Avatar
The black plastic rocker panel.
Old 11-28-2006, 10:35 PM
With the two screws out; pull downward to release the five lower rocker panel retainers from the body, then pull outward to release the 8 fasteners from the body.
Old 11-29-2006, 06:07 AM
joedirt's Avatar
Thanks! I will try that.
