Old 11-28-2006, 09:42 PM
rusty rusty is offline
rusty is off the scale
Default lube question
has anyone been able to lube the top nipple(not the one on the arm) in this pict without removing the skidplate??
Old 11-29-2006, 12:00 AM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Default Re: lube question
You can buy a 90? Zerk to make the job a little easier, also turning the wheel fully to one side sometimes provides clearance.
Old 11-30-2006, 02:01 PM
H2bill H2bill is offline
H2bill is on a distinguished road
Originally Posted by PhilD
There was a TSB on this and if I recall dealers were supposed to replace the fitting with a 90* one as and when they lubed it. But I've not heard of that happening much.
You can get a side mount nozzle for your grease gun, or as suggested just change it out for a 90*, it is really easy to do.
Meaning, you just unscrew the one in there and replace with a 90? Do you know off hand what size it is?
Old 11-30-2006, 04:57 PM
Oops, wrong thread. I saw "lube" and "nipple" and figured it was the woodshed.
Old 11-30-2006, 05:03 PM
Yes.
Can't recall, but pretty sure it is metric, so 6 or 8mm. Just take the existing one out and take it to the store with you.
The zerk fittings are the 1/4" size.
I replaced mine about 5 minutes. I like these 90 degrees valves so much that I also changed a couple of the lube ports on my Suburban too.
I can reach that valve with my skid plate ON. However, I have an H2Oguy aftermarket skid plate. In any case, you need a grease gun with at least an 18" hose.
