11-30-2006, 08:54 PM
Re: Is it "flesh out" or "flush out"?
what debate, that's pretty dumb. Both idioms are used all the time. You give a brief idea about something and then say you will "flesh it out" later to give it more substance and work out the details.
On the other hand, you are working on a project and have all sorts of questions and ideas that are unclear and you state you'll "flush it out" and report back what you figured out.
11-30-2006, 08:56 PM
Both idioms are used all the time -- incorrectly.
11-30-2006, 09:00 PM
11-30-2006, 09:01 PM
Flesh out - expand upon; work out the details; build up.
Flush out - clear out; so as to locate something; eliminate or remove the noise.
Well have to let the language correctness console argue about it though. I've got to remove my center council to do some more wiring projects.
___________
Edited to allow my point to speak.
'03 pewter base H2
11-30-2006, 09:03 PM
Flush out - clear out, so as to locate something, eliminate or remove the noise
Irregardless of your punctuation, I think your point is mute.
11-30-2006, 09:06 PM
11-30-2006, 09:09 PM
'03 pewter base H2
11-30-2006, 09:32 PM
The point is supposebly incorrect.
11-30-2006, 09:35 PM
If I wanted you're advise, I would have axed for it.
11-30-2006, 09:37 PM
I think he was just insuring that your point was solidly made. Incorrect does mean the same as correct, no?
'03 pewter base H2
11-30-2006, 09:38 PM
Rallegebly you did axed me a kwickshun.
