Old 12-02-2006, 03:16 AM
spark spark is offline
spark is an unknown quantity at this point
Default Instrument cluster Problem
Was heading out on my lunch break today and it started up just fine but when i looked at my instrument panel it was completely dead. It caught my attention because i though my gas was on E but the gauges were all dead and so was the LCD readout. I pushed the odometer reset rod and it fired up. Just kinda weird. If it happens again i will take it in but has this happened to anyone else? and have you taken it in? what was the problem?
Old 12-02-2006, 04:11 AM
K9sH3's Avatar
K9sH3 K9sH3 is offline
Default Re: Instrument cluster Problem
I would still let your service dept know of it.
Old 12-15-2006, 02:31 PM
DarkEye's Avatar
DarkEye DarkEye is offline
DarkEye is on a distinguished road
This exact thing happened to me yesterday while driving. Panel was normal when started up. While moving at 70mph I noticed that all gauges were dead and not lighted . I hit the right blinker and they all went back to normal and working. The battery light stayed on though. I pushed the On-Star and had them do a diag but no codes came back. When I stopped at a store I turned it off and started back up with no problems and gauges worked again all the way home.
I will wait util it happens again before taking it in for service. Kinda scary when it happened.
07 H3 Slate Blue, Lux Package, front brush guard, top rails, mud flaps, side steps.
Old 12-15-2006, 02:50 PM
H3.007 H3.007 is offline
Sounds like a loose wire or a bad relay. F5?
Old 12-15-2006, 06:08 PM
No relays. Loose connector at rear of cluster, or BCM is having a stroke.
Lower steering wheel, grab the cluster trim plate at the top and pull back to disengage the fasteners from the I/P, then remove four screws and check that connector is firmly attached to cluster.
