Old 12-19-2006, 07:59 PM
vip808 vip808 is offline
vip808 is off the scale
Default troubleshooting DRLs
Today I noticed that my DRLs were not turning on. My headlights turn on when I start the car and they stay on even in the day. Does anyone know where to start troubleshooting my problem? I checked the switch and it was set on "auto" I cleaned the sensor on the dash..I checked the fuse, but could not find one for the DRLs.. am I missing anything?
Any help would be greatly appreciated.
Old 12-19-2006, 08:29 PM
ree's Avatar
ree ree is offline
Default Re: troubleshooting DRLs
Since your headlamps are always on, I don't see how it could be fuse related.
If the sensor on the dash is indeed clean and you weren't just spreading gunk around on it, then it sounds like it's gone bad. I assume it's using a photoresistor that reduces resistance when light hits it. In this case a bad one will probably make the truck think it's dark out. T'is speculation, however. I suppose it could be faulty wiring to the sensor as well.
'03 pewter base H2
Old 12-19-2006, 09:29 PM
ree,
thanks, would you recommend a cleaner to use.. i just wiped it with a clean microfiber cloth..
Old 12-19-2006, 09:52 PM
ree's Avatar
ree ree is offline
Originally Posted by vip808
ree,
I'm pretty sure that if you bothered to rub it with any sort of cloth that would have been good enough.
'03 pewter base H2
Old 12-20-2006, 09:28 AM
Ree,
I went back and used a cleaner and a micro fiber cloth that I use for my camera lenses and "presto" working DRLs...
Thanks again for the help and Happy Holidays!!
