Old 12-27-2006, 06:46 AM
KCJohn's Avatar
KCJohn KCJohn is offline
KCJohn is off the scale
Question Monsoon XM and Factory Antenna
I have a Monsoon 6 disk system and want ot ad XM. If I use a system like the Trek GM XM radio can I attach it up to the factory XM / Onstar antenna? Or does someone make an antenna adaptor (or at least all the parts to make one) that could be used?
There's enough antennas on the truck already!
06 Black
Adventure package
Factory Undercarriage Protection
Factory Rocker Panel Guards
Gobi Stealth Rack
Gobi Lader
Driving Lights(4)
Flood Lights (rear)
Tail Light Guards
Predator winch package
Old 12-27-2006, 01:57 PM
Default Re: Monsoon XM and Factory Antenna
You can't use the actual Onstar lead, since it is used to receive GPS signals; however there should be a separate lead that is not connected to anything, and that would be the XM lead and can be used with any XM unit. There may be a need to revised the connector where it plugs into the unit.
Old 12-28-2006, 01:00 AM
KCJohn's Avatar
Would the extra lead (the one that would be used for the factory XM be found where the XM receiver is or do you think that they even put the lead off the antenna block?
06 Black
Adventure package
Gobi Stealth Rack
Gobi Lader
Driving Lights(4)
Flood Lights (rear)
Tail Light Guards
