Old 01-03-2007, 06:45 PM
Default Check engine light
Is running a couple of lean codes. New fuel pump and O2 sensors have not solved the problem. Any ideas? Intake manifold, maybe?
Old 01-03-2007, 06:57 PM
NewHummerGuy's Avatar
Default Re: Check engine light
Mine came on a couple months back. Took it in and was the catalytic converter. 35k miles on 2003. They just replaced as they are covered for like 80k miles or something.
Just a thought.
I'm Gonna crazy you my body
Old 01-03-2007, 10:53 PM
Could be a cat, or:
Bad injector (run a can of Techron through the fuel system. might help, it does a great job of cleaning injectors)
Bad vacuum hose (you can try the old propane trick to see if idle increases when the propane comes near a cracked vacuum line)
Opening past the MAF sensor in the tube to the throttle body
Old 01-03-2007, 11:18 PM
this is likely if you had anything done to the front of the engine, ie A/C, belt, etc. They will take off the deer antlers of an intake system (in my case it was just a straight aftermarket MIT) and when they put it back on they don't take their time and pinch the rubber seals.
Old 01-03-2007, 11:48 PM
The biggest issue here will be to diagnose anything in Adam's engine bay.
I have seen this before and I bet it has 100lbs of mud caked everywhere. There may be rodents living in there by now.
