Old 01-11-2007, 05:36 AM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
Default TORSION BAR PICTURES
Since no one that I know of has posted pics of the actual torsion bar Job getting done I figured it would be a nice post to have.
TBAR INSTRUCTIONS.
The front bar adjustments are located roughly under the divider between the front and rear doors--it is a bolt that is 1 1/16th inch. Measure from ground to bottom of fender BEFORE turning, then jack it up, turn CLOCKWISE the number of turns you want, then set down--remeasure.
***NOTE*** YOU MUST THEN GET IT ALIGNED.
I would use at leas a 21" 3 Ton Jack a bit overkill on the tonage but you need the height. Also no standard socket set has the 1 1/16 Socket so go to Sears and spend $10.69 on the socket. I would buy the DEEP socket as well for you will need the leverage. Make sure you have a breaker bar handy, the first two turns are pretty easy but the last 1/2 a turn is a bear. Make sure you have the truck tires off the ground in the front during the TBAr nut turn or it is next to impossible to turn the bolt.
This was a very easy Job. We did three trucks in less than 1 hour. The funny thing is in each truck the passenger side was nearly 1 inch lower (Stock Height) SO much for Hummer Engineering ;-) But than again thats what makes them Hummers..... Good Luck :0
JACK LOCATION
TBAR BOLT LOCATION
TBAR BOLT
Make sure you mark the bolts with a sharpie and turn CLOCKWISE.
The 35's 315/75 R 16 BFG Mudd Terrain. I am trading in my 33" Toyo Open Country M/T's :-(
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
