Old 01-11-2007, 07:18 AM
GLBLWARMR's Avatar
Default Not Hummer related but still need help....
I just picked up a 98 Dodge Durango "cheap" for my oldest boy when he gets his license here shortly. The guy said that a coolant leak just started. Well I went through the cooling system and found that the two rear freeze plugs on the side of the block were leaking. Well I am about to take off to Thailand for 2 weeks and wanted to do a quick fix until I returned to spend more time fixing the problem. Well tonight I took epoxy puddy and filled around the two leaking plugs. Those are now fixed but I am still loosing coolant towards the back of the engine where the tranny bolts to the engine. I have looked on line and cannot get a guaranteed answer as to the freeze plug locations of the Dodge 318 engine. I have heard that there are two on each side of the engine block and possibly two more on the rear of the engine where I am still leaking. Everything else is in great running order in this truck.
I am just checking if there is anyone on here that might be able to tell me if there are freeze plugs on the back of this engine and possibly provide a diagram. I looked at the local parts stores for the chiltons manual but they are not in stock right now and there is no point in ordering since I will be gone for two weeks. Thanks.
Russ
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
