Old 01-14-2007, 05:50 PM
culrich culrich is offline
culrich is off the scale
Default Wiring Diagram for Stock 6 Disc XM Head Unit?
Hello All. I picked up a Raytel TellPhone 4200 (bluetooth adapter through the radio) and, wtih the help of many threads here, finally figured out how to get the center dash out... sheeshh...
Anywho, the guy I ordered from indicated the instructions for the "splices" into the existing radio would be packaged in there... of course they're not.
Like a true enthusiast, I could not wait to get the dash off...
Guess I should have waited until monday for the wiring instructions.
I've found a couple of threads that referred to wiring instruction threads, but they all lead to dead links with a bad "m" value (whatever that means).
I need to splice (using a clip to "jumper" to the existing wire without cutting the existing wire) three lines:
My Green to the "line in ground (Telephone)"
My purple to the "line in positive pin"
My yellow to the "mute" pin
Shocking how many pins are on the back of the stock head unit, and I certainly do not want to guess...
Does anyone have a wiring diagram that they could post or a link to one?
If you just know and can indicate - and specify which cluser of wires on the head unit (there's two I believe) I would be very greatful!
Oh yes... 2007 H2 stock unit - 6 Disc with XM, no Nav (using NUVI 350 from the 2004 H2 I just traded in)
And for a great laugh... you should have seen my wife's face, looking at the new car, opening the door and the dashboard in the back seat.
THANKS !!!
