Old 01-24-2007, 12:11 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Default FS Magnuson Radix SC 5th gen.
RADIX 5TH GENERATION
The Magnuson/Eaton Model Radix 5th Generation is a “State of the Art” supercharger, engineered for 4.8 to 6.0 liter passenger cars and light truck engines. It was designed as a compact, flexible supercharger for increased power with original equipment quietness and reliability without adversely affecting fuel economy. The Radix has proven itself in a number of original equipment and aftermarket applications on a variety of engine sizes. This latest version has taken this versatility to the next level with “S Port” technology and a built in bypass for unparalleled performance.
  • Most installations see a realistic 40% plus increase in power output.
  • Magnuson/Eaton Superchargers will work effectively in any orientation (flat, upside down, on edge).
  • Different length drives are available, giving the custom installer flexibility in the placement of the supercharger.
  • Magnuson 5th generation superchargers have internal bypass valves. The bypass actuator can be located in any of 12 possible locations (6 on each side of the supercharger).
  • Shown with generic one-piece drive. Two-piece and different one-piece drives are available, as are pulleys with variable offset giving a wide range of possible drive lengths.
  • Two-piece extension drives available in 1" increments. Drive pulley offset design offers further options.
STANDARD EXTENSION DRIVES
For 5th Generation Superchargers
Drive LengthRange with 6-Rib R&D PulleyRange with 8-Rib R&D Pulley1"3.2" to 4.5"3.2" to 4.8"6"8.2" to 9.5"8.2" to 9.8"7"9.2" to 10.5"9.2" to 10.8"8"10.2" to 11.5"10.2" to 11.8"9"11.2" to 12.5"11.2" to 12.8"10"12.2" to 13.5"12.2" to 13.8"
Used, 15,000 miles. Works great!!!
Make offer!!
Real offers only please
Old 01-24-2007, 12:43 PM
drmiles's Avatar
Default Re: FS Magnuson Radix SC 5th gen.
OOOOOPPPS, THIS NEEDS TO BE IN THE H2 SECTION
MY BAD!!!
