Old 01-26-2007, 07:01 PM
Mr. I - Man's Avatar
Exclamation Dextron III or VI in tranfer case???
Was just wonder if Dextron VI is better than III in the transmission would using in the transfer case be a good idea???? Or should I stick with the III ???
Old 01-26-2007, 08:04 PM
pdsq99f4 pdsq99f4 is offline
Default Re: Dextron III or VI in tranfer case???
GM says stick with the dextron 3.
Old 01-30-2007, 11:11 PM
Christian GM Christian GM is offline
Christian GM is off the scale
GM say that Dexron VI can be used in all automatic transmission, and must be used on the A/T of model year 2006 and later.
I note that changing the A/T fluid from the III to the VI the A/T shifts really better.
GM say that Dexron VI absolutely can't be used in place of the III in manual transmission (for example the Corvette) and transfer case.
regards
Old 01-31-2007, 01:04 AM
tomp's Avatar
tomp tomp is offline
Use Dex III in TC and Dex 6 in tranny.
Is okay to use Synthetic Dex III as some have found break-down of dino in TC!
Old 02-01-2007, 12:14 AM
Too late put in Royal Purple Dex III. Alot less clunking going on back there now.
