Old 02-07-2007, 03:18 PM
Wilstruck's Avatar
Wilstruck Wilstruck is offline
Wilstruck is on a distinguished road
Default Tunner?
I have a K&N cold air intake and magnaflow catback exhaust on my truck. Question is should i get a tunner or not? Is it worth it as far as performance (gains) and if so what are some recomendations?
Wil
04 White Lux
93 Supercharged Lightning
Old 02-08-2007, 03:23 AM
Default Re: Tunner?
If You do not go with tuner after what you have done you will not get all out of the other upgrades that they can bring to the table. You increased ability for air flow in and out but, nothing to add more fuel and timing to get the real power You have set yourself up to have.
TAZ
Old 02-28-2007, 05:23 AM
Wilstruck's Avatar
Default Re: Tunner?
Well i purchased a hypertech power programmer III for my rig. With what i have installed as far as intake and exhaust any suggestions on settings for best performance? according to what i have read in other post (unless someone tells me different) setup will be as follows:
2004 Hummer H2
87 Octane
128 MPH
6100 Rev Limiter
Increase shift firmness
Gear Shifts
1-2......+3
2-3......+5
3-4......+7
Does this look good or has someone found a better tweek?
Wil
04 White Lux
Old 03-28-2007, 04:38 PM
mnorris101 mnorris101 is offline
mnorris101 is on a distinguished road
Default Re: Tunner?
Wil,
I was looking at making the same exact miodifications to my truck. Are you happy with what you have setup?
Old 03-28-2007, 05:28 PM
Wilstruck's Avatar
Default Re: Tunner?
yes very noticeable difference. It actually feels like i have a passing gear and some balls to get around people.lol I would say worth the investment!!!!!!
Wil
04 White Lux
Old 03-29-2007, 02:10 AM
Default Re: Tunner?
hmm, i think iam running everything the same but 3,6,9 do you have stock tires or did u re-calibrate for those??
Old 03-29-2007, 02:23 AM
Wilstruck's Avatar
Default Re: Tunner?
I'm running stock tire size.
Wil
04 White Lux
Old 03-29-2007, 03:04 AM
tomp's Avatar
tomp tomp is offline
Default Re: Tunner?
Why are you guys holding off from shifting longer? Doesn't the power start to drop off at about 5200 RPM?
