Old 02-07-2007, 06:51 PM
zmanH2's Avatar
zmanH2 zmanH2 is offline
zmanH2 is on a distinguished road
Question Brake Controller connection in '06s
Hi all! I have searched and read all the threads regarding brake controllers/wiring/connections in this forum and have left me dizzy . It looks like GM screwed up the wiring in the earlier models, then fixed it in the next models, now messed up again?
I also read the manual and have located the plug under the dash by the steering column. I will be towing a small popup camper (Fleetwood Tucson) weighing approx. 1,800 lbs loaded.
1). Is the "right" brake controller harness now availble for the 2006 model? I guess you will need this instead of splicing the wires under the dash if you are using say the Tekonsha Voyager or the Draw-Tite Activator.
2). Is there a brake controller that would just connect to the existing plug under the dash?
3). Can you guys suggest a controller for the relatively light trailer I am pulling?
Thanks!
HUMMER Like nothing else.
Old 02-10-2007, 06:51 PM
zmanH2's Avatar
Default Re: Brake Controller connection in '06s
Wow! With all the toys & stuff everyone's hauling here, any help?
UPDATE: I purchased a Tekonsha Voyager now so any help/tips on the install on a 2006 is appreciated.
http://tekonsha.com/tevoyagerintro.html
Old 02-11-2007, 02:30 AM
tomp's Avatar
tomp tomp is offline
http://www.elcovaforums.com/forums/s...ighlight=brake
