Old 02-14-2007, 02:05 AM
mgorsline mgorsline is offline
mgorsline is on a distinguished road
Default Torsion bar adjustment
Just had a couple of questions. What is the procedure for adjusting the torsion bars to level the vehicle? And is it always necessary to get the front end realigned after doing so?
2007 Adv. package, auto, black
Old 02-14-2007, 03:33 AM
marin8703's Avatar
Default Re: Torsion bar adjustment
heres a write up another member did on how to adjust the torsion bars: http://www.elcovaforums.com/forums/showthread.php?t=23733&highlight=torsion+instructi ons
Old 02-14-2007, 07:33 AM
whaaaaT whaaaaT is offline
whaaaaT is on a distinguished road
ha i turned mine till the yellow jounce bumpers were just off the arms by a little bit. I didnt make any lines, didnt count turns, turned a different amount on each side, and i didnt get an alignment. I did it at about 2,000 miles. I've got 14,000 now. Tires look fine to me. I broke all the rules. I was thinking about turning it a little more to see if the ride got smoother or worst. I want to find the best smoothness posible.
Old 02-14-2007, 03:59 PM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
Whaaaaaat a Rebel
In any case mine and the 7 trucks we did needed to be aligned. Iam sure if you had brought yours in you would of seen that yours needed it as well. I wrote those instructions that you did not follow based on experience with torsion bar turns and owning over 7 Hummers. If you WANTED the SMOOTHist ride you should of re-aligned the truck. Also you should turn your light beams down 2 cranks counter clockwise.
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 02-14-2007, 04:01 PM
BACKNBLACK's Avatar
Yes unless you want pre-mature tire wear and a not as smooth ride :-)
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
Old 02-14-2007, 11:35 PM
yea i was gonna get an alignment but i cant stop messing with em. lol. i go down and up and down and up. ha. I need them perfect.
Old 02-15-2007, 06:35 AM
tomp's Avatar
tomp tomp is offline
I just added the shock extensions to my H2 after cranking my torsion bars and the ride is just like OEM. In fact, I now have more downward travel than when it was stock. Something you all might want to consider.
Shortening your downward travel is what causes the basketball affect when torsion bars are cranked. Adding the shock extensions does several things positive.
First, it fixes a problem where my shocks used to bottom out before anything else, thus preventing early shock failure. Second, not only does it bring back the downward travel I lost, but it gives me more downward travel than stock
Old 02-15-2007, 03:49 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
hhmmm... And I thought folks were just flipping me off because it was a Hummer..
Rob
