Old 02-19-2007, 09:49 PM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Default diesel problems???
Any body else seam to be having more problems than usual with the NEW DIESEL.
Last couple of winters no problem. this year she's tried to cut out on me a few times. and the only thing I can think to cause it is this newer cleaner diesel.
anybody else have the same problems??
Old 02-19-2007, 10:59 PM
ssgharkness020147's Avatar
Default Re: diesel problems???
Are you running additives? If not probably the cause of you issues. You NEED to run additives every single fill up with the new ULSD that you are using due to the loss of cetane. Thank god we dont have it here yet.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 02-19-2007, 11:24 PM
talked to one of my buddies. he belongs to the turbo diesel register forum for Dodgy Rams. apparently the Ram owners are having a lot of problems with seals going due to the new diesel not having the same addatives as the old stuff. how can that be more enviromentaly friendly having your diesel dripping all over the road??
Old 02-20-2007, 04:02 PM
leenigen's Avatar
leenigen leenigen is offline
leenigen is off the scale
Any suggestions on the additive to use? I've been using Diesel 911 for a couple of years and it seems okay. Always looking for something better though.
Old 02-20-2007, 06:04 PM
Most people really like the Stanadyne product. Lucas injector cleaner works ok too if you cannot find the Stanadyne. Powerservice is good too, usually thats what I use. FWIW the Diesel 911 that you are using is the wrong stuff to use. Actually its not good for your engine at all. 911 is used to get you back on the road when your tank gells up, most products that do this have alcohol in them which is death to a diesel. You should switch to the Powerservice stuff in the white can, the grey can will work too, but that is a better summer additive.
-007=
Old 05-29-2007, 05:59 AM
Carbine Carbine is offline
Carbine is on a distinguished road
Try about a pint of transmission fluid to a full tank of fuel. I don't believe that it is the cetane rating. It's probably the lubricity. Throttleshaft seals need it. That injector pump sure needs it. Besides Tranny fluid cleans pretty well.
Old 05-31-2007, 09:01 PM
hmcoleap's Avatar
hmcoleap hmcoleap is offline
hmcoleap is on a distinguished road
Stanadyne Performance Additive - it is made by the manufacturer of the injection pump/fuel delivery system in your Hummer.
THE PREMIUM ALL-SEASON, ALL- PURPOSE DIESEL ADDITIVE. NO OTHER FUEL CONDITIONER PROVIDES ALL THESE BENEFITS.
Year-round application - improves performance in summer and in winter. Reduces No. 2 fuel pour point by up to 40 degrees Fahrenheit.
Improved horsepower - with up to a 5 point cetane rating gain, resulting in noticeably better acceleration; fewer downshifts, etc.
Increases fuel economy - more efficient combustion and increased power can result in up to 8% improvement in MPG, thus easily paying for itself.
Easier and faster start-up - especially from cold.
Reduced smoke and particulate emmisions - cleaner burn.
Longer service intervals - detergents protect and clean injectors and help remove deposits and prevent plugging. Lubricants reduce wear of costly injection system components.
Upgrades and stabilizes fuel - No need to buy expensive blended fuel. Reduces sludge and fuel tank contaminants.
Alcohol free - Avoids corrosion and accelerated wear.
Size *8 oz. Pint 1/2 Gallon 5 gallon 55 gallon Treatment (1:500) 30 gal. 60 gal. 240 gal. 2,500 gal. 27,500 gal. * Special formulations are used for the 8oz ONE SHOT treatment
https://shop.dieselpage.com
-- Manny
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
manny(at)serious4x4.com
http://www.serious4x4.com
