Old 02-23-2007, 02:01 AM
vlxjim's Avatar
vlxjim vlxjim is offline
vlxjim is on a distinguished road
Default Ultimate iPod adaptor
I'm new here, I have a new 06 H2. But I did want to post over here to you H3er's I've been told that the iPod install that I did is much the same as the H3 install so this might help some of you.
I just finished installing the American International Neucleus NC-X2i in my 2006 H2. After much research I found this little gem that you could install in less than 10 minutes. With full Text and iPod function over the iPod using the radio and steering wheel controls. There are no special labels that you need for the play list like on other units out there you can also use the iPods controls as well. This is not some poor quality RF solution either. This is a high sound quality wired in pre amp level adapter. As a bonus you also get an auxiliary input that you can hook up your DVD sound to or other pre amp source to.
Here is the link to the full write up hope it helps.
http://www.elcovaforums.com/forums/s...ad.php?t=24972
06 H2 Limited SUV Pacific Blue
