Old 02-26-2007, 08:36 AM
KrazyMedicRN's Avatar
KrazyMedicRN KrazyMedicRN is offline
KrazyMedicRN is on a distinguished road
Lightbulb Train Horn Mounting in SUT
I have seen how other people have posted their horns before but I am looking for suggestions on a possible bracket design that will hold the compressor and tank so they don't have to be mounted directly to the wheel well.... below are pictures of the items I plan on using as well as some previous pictures from other installs.
any info or suggestions would be appreciated.
These are the horns I am going with
I am adding triple solenoids and will be running 2 3/8" Braided Lines from the tank thru the Drain hole... one will power the horns and the other is planned for running a second line with a quick connect for airing up and using a ratchet if works
I am going with a 3 gallon tank
and a Air Zenith Compressor with a 175 psi pressure valve on the tank
Thanks in Advance
Rich
Picture of my 2005 H2 YELLOW SUT
http://www.myspace.com/krazymedicrn
