Old 06-07-2004, 02:51 AM
MMPH2 MMPH2 is offline
MMPH2 is off the scale
I got everything bolted onto the H2 just fine (at least I think I did everything right...it looked right), but I couldn't get the black plastic grill to snap back into place. Part of the brush guard bracket (where the 2 screws go into the H2) keeps me from getting close to the holes for the clips to snap.
What am I doing wrong? I'm not good at doing installs myself, so I may just be doing something wrong. Maybe someone can tell me where I can find the proper "Hummer installation guide" that would come with the guard?
Thanks!
2003 Hummer H1 open top
2011 Mercedes C63
Thanks!
2011 Mercedes C63
Thanks!
2011 Mercedes C63
Old 06-07-2004, 11:14 AM
Big Z Big Z is offline
Check out this link. Mark it with a pencil, then saw out.
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=578605269 1&r=8206023691#8206023691
Old 06-07-2004, 12:10 PM
Thanks! I tried doing a "seach" on this topic, but this thread didn't come up. It's much appreciated!!!
2011 Mercedes C63
Old 06-07-2004, 02:00 PM
Hog Hunter Hog Hunter is offline
Hog Hunter is off the scale
I had the same problem, but was easily remedied by cutting out (or using a dremel tool) that portion of the grill which got in the way. Took less than 15 minutes with my dremel tool to modify. Good luck.
Pewter 2004 H2, Warn Winch, Husky Mats, No leather or sunroof, Garmin rino 120, stainless DSA FAL carbine w/ aimpoint red dot and my trusty cocker spaniel.
Old 06-07-2004, 02:36 PM
Circuitguy
There is a different lower grill sold threw your H2 dealer that is moulded without the sides on it. Have your local dealer check it out if you don't want to do any cutting. BIG-C
Old 06-07-2004, 02:47 PM
Yeah...but isn't it like $120? I don't mind spending $, but I'd much rather put $120 toward the Real Wheels Air Horn.
2011 Mercedes C63
Old 06-07-2004, 03:09 PM
I was quoted $140.00.
Old 06-07-2004, 03:44 PM
Just cut it. It only takes a second. I had to do it too and there is not problem with it. Piece of cake.
