03-04-2007, 12:46 AM
Airing up tires after wheeling
Need to know some options for airing up the tires after wheeling. I do not have the on board air system. What is everyone using?
2009 H2 Silver Ice LE
03-04-2007, 01:17 AM
Re: Airing up tires after wheeling
Power tank. It takes about 30sec/ tire. I aired up five times so far and will have to refill soon. It's safe and works very well. I've given up on compressors. they take too long. The power tank takes up some room, but IMO, it's worth it.
http://www.powertank.com/
03-04-2007, 01:23 AM
is the power tank like a high pressure scuba tank sort of thing? I assume you get it filled up at a dive shop or something on that order?
03-04-2007, 03:09 AM
No, not a scuba tank. Read the info on the web site I provided. It goes through a FAQ. Scuba tanks are completely different in cylinder and valve design and scuba tanks cannot be used in place of a CO2 tank.
Any welding shop can fill these. It costs me around $9.00 to fill it.
03-04-2007, 03:26 AM
gotcha....going to the FAQ now. I didnt notice this was a CO2 tank when i scanned the website initially.
Thanks for the tip Tim its much appreciated.
03-07-2007, 03:58 AM
My onboard air compressor takes forever with 37s. I usually just drive it to a gas station.
The air tanks are great but they are $$$.
03-07-2007, 04:09 AM
With a tank that has enough pressure, you can also reseat a bead if necessary.
03-07-2007, 06:57 AM
'03 H2
03-07-2007, 09:29 AM
If you're planning on running air tools, you won't want to go with the ride-rite/firestone one.... here's what it says in the manual:
THIS KIT IS NOT DESIGNED TO RUN AIRPOWERED TOOLS.
THE COMPRESSOR IS DESIGNED TO RUN AT A 20% DUTY
CYCLE WITHA MAXIMUM RUN TIME OF 6 MINUTES. PLEASE
ALLOW ADEQUATE TIME FOR THE COMPRESSOR TO COOL
BETWEEN RUNNINGS.
'03 H2
03-07-2007, 09:30 AM
That looks like a really good price on the viair constant duty setup....
'03 H2
03-07-2007, 03:38 PM
Quick Air II
03-07-2007, 05:53 PM
Quick Air II
QUICK?  They should call it a slow air.
...but is reliable.
