Old 03-09-2007, 06:53 PM
rrboy rrboy is offline
rrboy is off the scale
Default for those looking for toyo mt's
I was surfin the web last night and found a great deal on toyo mt's. I have no idea if this guy is for real, but if it is..thats a good price for the
LWM Transportation Enhancement
Contact the seller instantly
Toyo Open Country MT Tires
Size35x12.50x17Load RangeLoad Range E
Max Load 3640
Height and Width34.8"x13.2"DescriptionAll Around Traction
- Aggressive, attack tread design with hook-shaped blocks
- Scalloped shoulder blocks
- Tread block stabilizer
- Deep siping in the tread blocks
- Open shoulder design
Styling
- Over-the-shoulder tread
- Black outline serrated lettering
- Rim protector in lower sidewall
Excellent Handling On/Off Road
- DSOC II? Technology
- High turn-up, 3-ply casing
- Two wide steel belts
- Two spiral wound nylon cap plies
- High bead filler
Excellent Grip In All Elements
- Cap/base construction
- Tread block stabilizers
- Open, scalloped shoulder blocks
Smooth, Stable Ride
- Computer-optimized tread design
- Advanced production technology for unheard of levels of uniformity
- Tread elements shaped and staggered for reduced noise
- 3-ply polyester casing
- Single strand, jointless bead wire construction
Durability and Long Life
- High turn-up, 3-ply polyester casing
- Bruise and abraision resistant sidewall compound
They are brand new FIRST LINE tires, in brand new condition, with zero miles on them. ;
